Change naming rule to the ProblemReport Item
I'm trying to change the naming rule to the ProblemReport Item. But bmide stop me to do it.
The problemreport item has already a naming rule by default. I can't remove it and can't add an other one.
Do you have some ideas ?
Best regards,
Re: Change naming rule to the ProblemReport Item
SIEMENS recommend to subtype COTS types for any configurations.
In case, you want to use the COTS ProblemReport type, try attaching your new naming rule with a condition other than isTrue.
Make sure, the condition result must be TRUE for all users who are trying to create Problem Report.
Best matching condition would be to use isProblemReportCreatable.
Mahendra
Thank you Smiley Happy
