Change ownership for bulk of items
Builder
Builder
Hi
we have a assembly with more than 100 items (multiple revisions under each revisions), They all located under a folder and imported manually using Teamcenter NX Manager import as a DBA user. now i want to change the ownership from DBA users to a normal user (who is not a DBA,). using EDIT--> Change ownership--->,
  1. I need to expand Item and all ites revsiions
  2. Shift+Select all the data under Item rev
  3. Use the Edit-->Transfership to change/transfer the owner
is there a way i can do this for whole folder of data, without expanding each Item/Item rev. if i dont expand teh Item it wont chnage the ownership at Item revsion level
Re: Change ownership for bulk of items
Try do this:
Click Button with icon on image:
 You will see your selected items, click button with icon on image:
This will make it possible to auto select all the child components
Builder
Builder
That was great tip, Thank you
