Changing ACLs, Cannot view dependencies
Cannot view model depencies on items and their datasets.
There is also a view folder within the dataset that when expanded allows you to see all parts and assemblies associated with that assembly(dataset).
When I am signed in as a DBA, everything shows(views and dependencies) when I or any other user signs on as Purchasing, Engineer etc and attempt expand the dataset nothing shows.
I narrowed it down to it being a privileges issue, but no matter what I change in the access control list nothing works. I want users to be able to see all dependencies by just clicking expand.
Re: Changing ACLs, Cannot view dependencies
Does a non-DBA user have read access to the objects?
What does he see under Where Referenced or Where Used?
