Changing default ITEM to custom ITEM
I deployed BMIDE with Custom item which has LOV's,  We are able to select LOV values from the custom Item but not from default item. So we would like to change all currect items to Custom Item. it is possible to change from currect items to Custom Item.
Venny
Re: Changing default ITEM to custom ITEM
Changing Item types usually requires ITK to reconcile the mapping of properties and preserving meta data.
Evaluating:AW 3.2
We may not do now. we will look into it
