Changing item names in TC
Hi guys,
A very basic question again.
How do we change an item name in TC?
Version 10.1.3
Thanks.
Cem
Re: Changing item names in TC
right-click on the item --> edit properties --> check out the item and edit the name --> Save and check in.
