Changing the Prefix of Engineering Order from EO to EDRS
Dear Experts,
When creating a new Engineering order the default prefix is shown as "EO"NNNNNN the customer wants this changed to "EDRS"NNNNNN. In BMIDE the EDIT option is disabled Eng_Order under Naming rules. Please guide on the alternative way for the same.
Thanks In Advance,
Jeethan Rohan
Best Regards,
Jeethan Rohan
Re: Changing the Prefix of Engineering Order from EO to EDRS
Do you know in which template the naming rule with pattern "EO"NNNNNN is defined? If it is another custom template that is owned by you, you can open that template and edit that naming rule's pattern to  "EDRS"NNNNNN.
If this is a COTS naming rule defined in a template that is not owned by you, then you can define a new custom naming rule with "EDRS"NNNNNN pattern and override the COTS naming rule by following the instructions mentioned in the TDOC section: Override a COTS naming rule
Thanks for the information,
Best Regards,
Jeethan Rohan
