Clearing the Temporary Files / Delete Cache
How do you clear the Temporary Files? Delete Cache?
4 REPLIES 4
Re: Clearing the Temporary Files / Delete Cache
Stop all tc processes, remove following folders
C:\Users\<username>\Teamcenter
C:\Users\<username>\FCCCache
Alternative to deleting C:\Users\<username>\FCCCache is running fccstat -purge or fccstat -clear.
Here is a small script to clean %TEMP% folder but keep the most recent files.
br
Fred
@ECHO OFF
set MAXDAYS=1
REM delete all files in subfolders
FORFILES /p "%TEMP%" /S /M *.* /D -%MAXDAYS% /C "cmd /c del /Q @path"
TIMEOUT 3
REM delete all subfolders (must be empty)
FORFILES /P "%TEMP%" /S /D -%MAXDAYS% /C "cmd /c IF @isdir == TRUE rd /S /Q @path"
TIMEOUT 3
Frederik Verscheure
Evolve Consulting bvba
Freelance NX & Teamcenter consultant
frederik@evolve-consulting.be
I have users run the attached script to clean up scratch and FCC files.
Larry Carpenter, P.E.
