Clicking Summary Tab leads to RAC Crash
Hi Everybody,
by a certain Item, the customer is experiencing a crash of the Rich Client whenever the Summary Tab is clicked.
This is happenening whenever the Item or it's revisions are selected and the then the Summary Tab is being clicked on.
Rich Client doesn'T respond and it has to be closed with the help of Task Manager.
The Problem is that this item is built in alot of assemblies, so it cannot be simply replaced.
Any Idea how to recover this item or solve the issue.
The RAC Logfile shows:
ERROR 2018-02-26 11:54:36,160 - SWT UI Thread is not responding!
FATAL 2018-02-26 11:54:36,179 - Thread[main,6,main]/java.lang.Thread [Alive]
   java.lang.Object.wait(Object.java:-2)
   java.lang.Object.wait(Object.java:503)
   org.jacorb.orb.giop.ReplyPlaceholder.getInputStream(null:-1)
   org.jacorb.orb.ReplyReceiver.getReply(null:-1)
   org.jacorb.orb.Delegate.invoke_internal(null:-1)
   org.jacorb.orb.Delegate.invoke(null:-1)
   org.omg.CORBA.portable.ObjectImpl._invoke(null:-1)
   com.teamcenter.tc.kernel.icctstubs._TcCorbaServiceGatewayStub.invokeMethod(null:-1)
   com.teamcenter.soa.internal.client.IiopTransport.executeRequest(null:-1)
   com.teamcenter.soa.internal.client.XmlRestSender.invoke2(null:-1)
   com.teamcenter.services.internal.rac.core.PresentationManagementRestBindingStub.getStylesheet(null:-1)
   com.teamcenter.rac.viewer.stylesheet.StylesheetRenderingService.getStyleSheet(null:-1)
   com.teamcenter.rac.viewer.provider.StylesheetCombinedContentProvider.inputChanged(null:-1)
   org.eclipse.jface.viewers.ContentViewer.setInput(ContentViewer.java:276)
   com.teamcenter.rac.viewer.stylesheet.viewer.HTMLStyleSheetViewer.setInput(null:-1)
   com.teamcenter.rac.ui.views.BrowserSummaryViewPart$1$1.run(null:-1)
   org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
   org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
   org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144)
   org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
   org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
   org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
   org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
   org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
   org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
   org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
   org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
   com.teamcenter.rac.aifrcp.Application.runApplication(null:-1)
   com.teamcenter.rac.aifrcp.Application.start(null:-1)
   org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
   org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
   org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
   org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
   org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
   sun.reflect.NativeMethodAccessorImpl.invoke0(null:-2)
   sun.reflect.NativeMethodAccessorImpl.invoke(null:-1)
   sun.reflect.DelegatingMethodAccessorImpl.invoke(null:-1)
   java.lang.reflect.Method.invoke(null:-1)
   org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
   org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
   org.eclipse.equinox.launcher.Main.run(Main.java:1438)
   org.eclipse.equinox.launcher.Main.main(Main.java:1414)
9 REPLIES 9
Re: Clicking Summary Tab leads to RAC Crash
It's not clear if this is one specific Item or all Items? Can you turn on Communications Monitor to see more of what is happening? Have you already validated the transient volume configuration(s)? Are they using Multisite (stub's)?
Thanks for your Reply.
-It's not clear if this is one specific Item or all Items?
This is happening by one certain Item.
-Can you turn on Communications Monitor to see more of what is happening?
DEBUG: 17:33:45,489  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.86282.01.infodba.00187 Internal-Core-2011-06-ICT:invokeICTMethod( ICCTDebugService.omPrintObject ) (291 bytes)
DEBUG: 17:33:45,493  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.86282.01.infodba.00187 Internal-Core-2011-06-ICT:invokeICTMethod( ICCTDebugService.omPrintObject ) (12438 bytes time: 0.003 seconds total: 0.003 seconds)
DEBUG: 17:33:45,549  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.86282.01.infodba.00188 Internal-Core-2011-06-ICT:invokeICTMethod( ICCTDebugService.omPrintObject ) (291 bytes)
DEBUG: 17:33:45,551  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.86282.01.infodba.00188 Internal-Core-2011-06-ICT:invokeICTMethod( ICCTDebugService.omPrintObject ) (12467 bytes time: 0.002 seconds total: 0.006 seconds)
DEBUG: 17:33:45,609  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.86282.01.infodba.00189 Internal-Core-2013-05-PresentationManagement:getStylesheet (415 bytes)
DEBUG: 17:33:46,159  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.50739.01.infodba.00190 Internal-Core-2011-06-ICT:invokeICTMethod( ICCT.getProperties ) (502 bytes)
DEBUG: 17:34:41,902  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.50739.01.infodba.00190 Internal-Core-2011-06-ICT:invokeICTMethod( ICCT.getProperties ) (667 bytes time: 55.740 seconds total: 55.746 seconds)
DEBUG: 17:34:41,906  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.50739.01.infodba.00191 Internal-Core-2011-06-ICT:invokeICTMethod( ICCTAccessControlService.checkPrivileges ) (404 bytes)
DEBUG: 17:34:41,909  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.50739.01.infodba.00191 Internal-Core-2011-06-ICT:invokeICTMethod( ICCTAccessControlService.checkPrivileges ) (397 bytes time: 0.002 seconds total: 55.749 seconds)
DEBUG: 17:34:41,914  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.50739.01.infodba.00192 Core-2006-03-DataManagement:getProperties (1417 bytes)
DEBUG: 17:34:41,916  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.50739.01.infodba.00192 Core-2006-03-DataManagement:getProperties (470 bytes time: 0.002 seconds total: 55.752 seconds)
DEBUG: 17:34:41,921  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.50739.01.infodba.00193 Internal-Core-2011-06-ICT:invokeICTMethod( ICCT.refresh ) (355 bytes)
DEBUG: 17:34:41,926  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.50739.01.infodba.00193 Internal-Core-2011-06-ICT:invokeICTMethod( ICCT.refresh ) (223 bytes time: 0.005 seconds total: 55.757 seconds)
DEBUG: 17:34:41,930  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.50739.01.infodba.00194 Core-2013-05-DataManagement:getChildren (1411 bytes)
DEBUG: 17:34:41,951  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.86282.01.infodba.00189 Internal-Core-2013-05-PresentationManagement:getStylesheet (11246288 bytes time: 56.332 seconds total: 1 minutes 52.089 seconds)
DEBUG: 17:34:41,965  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.50739.01.infodba.00194 Core-2013-05-DataManagement:getChildren (4156 bytes time: 0.034 seconds total: 1 minutes 52.124 seconds)
DEBUG: 17:34:41,976  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.50739.01.infodba.00195 Core-2006-03-DataManagement:getProperties (1461 bytes)
DEBUG: 17:34:41,977  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.50739.01.infodba.00195 Core-2006-03-DataManagement:getProperties (609 bytes time: 0.001 seconds total: 1 minutes 52.126 seconds)
DEBUG: 17:34:43,049  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.53233.01.infodba.00196 Core-2006-03-DataManagement:getProperties (1424 bytes)
DEBUG: 17:34:43,054  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.53233.01.infodba.00196 Core-2006-03-DataManagement:getProperties (358 bytes time: 0.005 seconds total: 1 minutes 52.131 seconds)
DEBUG: 17:34:43,054  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.86282.01.infodba.00197 Internal-Core-2011-06-ICT:invokeICTMethod( ICCTDebugService.omPrintObject ) (291 bytes)
DEBUG: 17:34:43,058  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.86282.01.infodba.00197 Internal-Core-2011-06-ICT:invokeICTMethod( ICCTDebugService.omPrintObject ) (12477 bytes time: 0.003 seconds total: 1 minutes 52.134 seconds)
DEBUG: 17:34:43,077  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.50739.01.infodba.00198 Core-2006-03-DataManagement:getProperties (1416 bytes)
DEBUG: 17:34:43,080  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.50739.01.infodba.00198 Core-2006-03-DataManagement:getProperties (466 bytes time: 0.003 seconds total: 1 minutes 52.138 seconds)
DEBUG: 17:34:43,084  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.50739.01.infodba.00199 Internal-Core-2011-06-ICT:invokeICTMethod( ICCT.getProperty ) (372 bytes)
DEBUG: 17:34:43,086  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.50739.01.infodba.00199 Internal-Core-2011-06-ICT:invokeICTMethod( ICCT.getProperty ) (369 bytes time: 0.001 seconds total: 1 minutes 52.139 seconds)
DEBUG: 17:34:43,451  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.53233.01.infodba.00200 Internal-Core-2013-05-Thumbnail:getThumbnailFileTickets2 (2482 bytes)
DEBUG: 17:34:43,473  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.53233.01.infodba.00200 Internal-Core-2013-05-Thumbnail:getThumbnailFileTickets2 (617 bytes time: 0.022 seconds total: 1 minutes 52.162 seconds)
DEBUG: 17:34:43,581  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.86282.01.infodba.00201 Internal-Core-2011-06-ICT:invokeICTMethod( ICCT.getPropertiesSet ) (596 bytes)
DEBUG: 17:34:43,582  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.86282.01.infodba.00201 Internal-Core-2011-06-ICT:invokeICTMethod( ICCT.getPropertiesSet ) (1458 bytes time: 0.001 seconds total: 1 minutes 52.163 seconds)
DEBUG: 17:34:43,586  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.61028.01.infodba.00202 Core-2013-05-DataManagement:getChildren (1411 bytes)
DEBUG: 17:34:43,618  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.61028.01.infodba.00202 Core-2013-05-DataManagement:getChildren (8049 bytes time: 0.032 seconds total: 1 minutes 52.195 seconds)
DEBUG: 17:34:43,623  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.61028.01.infodba.00203 Core-2006-03-DataManagement:getProperties (1420 bytes)
DEBUG: 17:34:43,625  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.61028.01.infodba.00203 Core-2006-03-DataManagement:getProperties (496 bytes time: 0.001 seconds total: 1 minutes 52.197 seconds)
DEBUG: 17:34:43,628  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.61028.01.infodba.00204 Core-2006-03-DataManagement:getProperties (1420 bytes)
DEBUG: 17:34:43,630  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.61028.01.infodba.00204 Core-2006-03-DataManagement:getProperties (496 bytes time: 0.001 seconds total: 1 minutes 52.199 seconds)
DEBUG: 17:34:43,635  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.53233.01.infodba.00205 Internal-Core-2011-06-ICT:invokeICTMethod( ICCT.getPropertiesSet ) (688 bytes)
DEBUG: 17:34:43,638  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.53233.01.infodba.00205 Internal-Core-2011-06-ICT:invokeICTMethod( ICCT.getPropertiesSet ) (3203 bytes time: 0.003 seconds total: 1 minutes 52.202 seconds)
DEBUG: 17:34:43,687  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.86282.01.infodba.00206 Internal-Core-2011-06-ICT:invokeICTMethod( ICCT.getProperty ) (389 bytes)
DEBUG: 17:34:43,688  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.86282.01.infodba.00206 Internal-Core-2011-06-ICT:invokeICTMethod( ICCT.getProperty ) (350 bytes time: 0.001 seconds total: 1 minutes 52.203 seconds)
DEBUG: 17:34:43,691  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.86282.01.infodba.00207 Internal-Core-2011-06-ICT:invokeICTMethod( ICCT.getProperty ) (391 bytes)
DEBUG: 17:34:43,692  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.86282.01.infodba.00207 Internal-Core-2011-06-ICT:invokeICTMethod( ICCT.getProperty ) (359 bytes time: 0.001 seconds total: 1 minutes 52.205 seconds)
DEBUG: 17:34:43,757  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.86282.01.infodba.00208 Internal-Core-2013-05-PresentationManagement:getStylesheet (415 bytes)
DEBUG: 17:35:39,222  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.86282.01.infodba.00208 Internal-Core-2013-05-PresentationManagement:getStylesheet (11244103 bytes time: 55.455 seconds total: 2 minutes 47.661 seconds)
DEBUG: 17:35:40,201  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.90284.01.infodba.00209 Core-2006-03-DataManagement:getProperties (1424 bytes)
DEBUG: 17:35:40,206  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.90284.01.infodba.00209 Core-2006-03-DataManagement:getProperties (358 bytes time: 0.005 seconds total: 2 minutes 47.666 seconds)
DEBUG: 17:35:40,492  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.50739.01.infodba.00210 Internal-Core-2013-05-Thumbnail:getThumbnailFileTickets2 (2482 bytes)
DEBUG: 17:35:40,502  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.50739.01.infodba.00210 Internal-Core-2013-05-Thumbnail:getThumbnailFileTickets2 (749 bytes time: 0.009 seconds total: 2 minutes 47.676 seconds)
DEBUG: 17:35:41,193  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.44716.01.infodba.00211 Internal-Core-2011-06-ICT:invokeICTMethod( ICCT.getProperties ) (471 bytes)
DEBUG: 17:35:41,195  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.44716.01.infodba.00211 Internal-Core-2011-06-ICT:invokeICTMethod( ICCT.getProperties ) (538 bytes time: 0.002 seconds total: 2 minutes 47.678 seconds)
DEBUG: 17:35:41,198  - CommunicationMonitorView.callMade:?
[Call]  NW81-W7.44716.01.infodba.00212 Internal-Core-2011-06-ICT:invokeICTMethod( ICCTAccessControlService.checkPrivileges ) (404 bytes)
DEBUG: 17:35:41,202  - CommunicationMonitorView.replyReceived:?
[Reply] NW81-W7.44716.01.infodba.00212 Internal-Core-2011-06-ICT:invokeICTMethod( ICCTAccessControlService.checkPrivileges ) (397 bytes time: 0.003 seconds total: 2 minutes 47.681 seconds)
-Have you already validated the transient volume configuration(s)?
What can I do there?
-Are they using Multisite (stub's)?
No
For the one specific Item issue. Can you attach the tcserver syslog and users tccs log? Hopefully one of them will shed light on what the issue is with the Item. If this problem isn't across the board with all Items then the transient volume isn't an issue and we have to explore the Item and its objects (obviously, something is missing).
Hello
Did you use summary stylesheets? On our site this creates crashes in the development environment when there is a problem with the stylesheets. I this problem on every rac?
Greetings Jens
Hi Randy,
TCserver logfile is showing:
ERROR: loader.cpp:684 08:15:14 Eigenschaft mit dem Namen TCEonly Revision/eju4_rp_CN01_DATUM konnte nicht gefunden werden.
ERROR: loader.cpp:707 08:15:14 Prop Type=TCEonly Revision Name=eju4_rp_CN01_DATUM not found: please reg with BMIDE
-call: loader.cpp:684 08:15:14 TCTYPE_ask_property_by_name
ERROR: loader.cpp:684 08:15:14 Eigenschaft mit dem Namen TCEonly Revision/eju4_rp_CN02_DATUM konnte nicht gefunden werden.
ERROR: loader.cpp:707 08:15:14 Prop Type=TCEonly Revision Name=eju4_rp_CN02_DATUM not found: please reg with BMIDE
ERROR: loader.cpp:684 08:15:14 Eigenschaft mit dem Namen TCEonly Revision/eju4_rp_CN03_DATUM konnte nicht gefunden werden.
ERROR: loader.cpp:707 08:15:14 Prop Type=TCEonly Revision Name=eju4_rp_CN03_DATUM not found: please reg with BMIDE
ERROR: loader.cpp:684 08:15:14 Eigenschaft mit dem Namen TCEonly Revision/eju4_rp_CN04_DATUM konnte nicht gefunden werden.
ERROR: loader.cpp:707 08:15:14 Prop Type=TCEonly Revision Name=eju4_rp_CN04_DATUM not found: please reg with BMIDE
ERROR: loader.cpp:684 08:15:14 Eigenschaft mit dem Namen TCEonly Revision/eju4_rp_CN05_DATUM konnte nicht gefunden werden.
ERROR: loader.cpp:707 08:15:14 Prop Type=TCEonly Revision Name=eju4_rp_CN05_DATUM not found: please reg with BMIDE
ERROR: loader.cpp:684 08:15:14 Eigenschaft mit dem Namen TCEonly Revision/eju4_rp_CN06_DATUM konnte nicht gefunden werden.
ERROR: loader.cpp:707 08:15:14 Prop Type=TCEonly Revision Name=eju4_rp_CN06_DATUM not found: please reg with BMIDE
ERROR: loader.cpp:684 08:15:14 Eigenschaft mit dem Namen TCEonly Revision/eju4_rp_CN07_DATUM konnte nicht gefunden werden.
ERROR: loader.cpp:707 08:15:14 Prop Type=TCEonly Revision Name=eju4_rp_CN07_DATUM not found: please reg with BMIDE
ERROR: loader.cpp:684 08:15:14 Eigenschaft mit dem Namen TCEonly Revision/eju4_rp_CN08_DATUM konnte nicht gefunden werden.
ERROR: loader.cpp:707 08:15:14 Prop Type=TCEonly Revision Name=eju4_rp_CN08_DATUM not found: please reg with BMIDE
ERROR: loader.cpp:684 08:15:14 Eigenschaft mit dem Namen TCEonly Revision/eju4_rp_CN09_DATUM konnte nicht gefunden werden.
ERROR: loader.cpp:707 08:15:14 Prop Type=TCEonly Revision Name=eju4_rp_CN09_DATUM not found: please reg with BMIDE
ERROR: loader.cpp:684 08:15:14 Eigenschaft mit dem Namen TCEonly Revision/eju4_rp_CN10_DATUM konnte nicht gefunden werden.
ERROR: loader.cpp:707 08:15:14 Prop Type=TCEonly Revision Name=eju4_rp_CN10_DATUM not found: please reg with BMIDE
Hello Jens,
the customer does not use custom Summary Stylesheets. This phenomenon is happening by only one Item.
Thanks in advance
Looks like there is some configuration in place when opening/displaying the Summary stylesheet? Like compound properties and visibleWhen portions of the stylesheet? Maybe an exhaustive LOV for revision name?
Prop Type = TCEonly
and
Revision Name = ??, where the revision name isn't expected (not configured in BMIDE) or not in an exhaustive LOV?
Was this Item imported from another / someone else's Teamcenter?
Hello SLR
the errors looks realy like a problem in the datamodell. Can you check your bmide for the properties of the item revision obejct and check the 10 eju4_rp_cnxx_datum properties? Are they realy there and which datatype are they and are they have a Lov attached?
Greetings Jens
Thank you, I will try it and give you feedback!
