Closure Rule - How to traverse from Item to BOM - for plmxml?
Hello, I need to traverse to BOM and find BOMLine properties.
In closure rule- I traversed from Item-> BOMView / BOMView Revision.
How do I get to reach to BOMLine?
I tried,
Primary = BOMView / R
Relation P2S =*
Secondary = BOMWindow / BOMLine
Please guide.
7 REPLIES 7
Re: Closure Rule - How to traverse from Item to BOM - for plmxml?
try this
Primary Object Class Type = Class
Primary Object = BOMWindow
Secondary Object Class Type = Type
Secondary Object = *
Relation Type = Property
Related Property or Object = top_line
Action = TRAVERSE_AND_PROCESS
Primary Object = ImanItemLine
Related Property or Object = bl_all_child_lines
may be a conditional clause = $bom_cb != "1" && PRIMARY.bl_window_is_BOPWin=="false"
with regards,
Chini
Thanks Chini.
But how do I traverse to BOMWindow from Item?
Actually, I am looking to create a Summary Report (not the Item Report).
Here, user will have some filters - like Item Id, Revision Rule,..
Now, I need to query the Item and traverse from it.
User will not be running the report from Structure Manager.
I could get BOMView, but how do I reach to the BOMWindow, so I can get the BOMLine?
If you are creating a summary report, what kind?
Summary report of Structure could be done using Report builder.
I need exact understanding of your requirement.
With regards,
Chini
The user will generate summary report. (Tools-->RepoortS-->Report Builder Reports).
Here, the fields are - Item Id, Revision Rule, Variant, Effectivity.
The report will fetch BOMLine as well as Item and Revision properties.
The requirement you gave is possible to realise. see the example reports in TC. You might get an idea.
We use TcRA for all reporting and analytics.
How do I traverse from Item revision to BOM ? Even I'm building a summary report and this should have the where used and its levels.. User does not run the report from structure manager.. So I  need the closure rule which will fetch the BOM .. Parent and child elements..
Please let me  know how to traverse till BOM? I'm not fetching any BOMLINE attributes here.. I just need to find which item is the parent/child of which?
Any help appreciated.
Shruthi
Hi Shruthi,
Did you get answer for it?
I also have the same requirement.
