Compare Preferences from two different sites
what is the best way to compare 2 xml-Files generated by the preferences_manager utility?
Re: Compare Preferences from two different sites
If you have Teamcenter 11.2 or higher, I think it's better to use Admin Data Tools
Generating administration data reports
https://docs.plm.automation.siemens.com/tdoc/tc/11.2.3/help#uid:xid1256816:index_plm00102:xid733779:...
Generate an administration data comparison report
Siemens Genius Siemens Genius
Siemens Genius
Hi Marco,
I use the following process:
  1. export preferences from both sites
  2. sort the xml files by XmlSorter (you can find multiple software libraries providing it) having care to sort by tag name and specific attribute (name); I use to sort attributes too
  3. compare the sorted files by BeyondCompare
This way you can easily find out the differences.
Paolo
