Corrupt Workflow Deletion
Builder
Builder
Sometimes, workflow creates an issue. While assigning the workflow, due to abnormal behaviour, user cannot put it into workflow.But Its showing workflow SYMBOL for that item. Using workflow viewer or in by passmode or deleting from inbox also not possible. We don't what's the issue.  Is there any way to delete corrupted workflow using any command utilities? or any other ways..
Re: Corrupt Workflow Deletion
Hi @SwamyRangu,
Check the following links from the Solution Center.
corrupt workflow: unable to delete
Procedure to delete corrupt workflow Icon
Ganesh
Builder
Builder
@GaneshKadole,
Thanks a lot.
