Count items in a folder
Does anyone know how I can check how many items/datasets is linked to a folder in Teamcenter 8.3 without counting them manually?
Re: Count items in a folder
I assume you mean TcSE (TCR)
Have you tried an advanced search (using the statring object) to ADD the Complying and Defining objects? The results window will tell you how many objects have been found.
Mark
Thanks for the reply!
I'm unsing TC 8.3 Unified Edition. Regarding your proposal I'm not getting exactly what you mean. Can you explain it some more.
Ok, I'm not using TCU so I don't know if this will work but in Teamcenter Systems Egineering this is what I would do ...
Select the Folder I'm interested in.
Select Search
Select Advanced
Selet Use starting object
Use the following search filter:
  • Select <folder name>
  •     For Each
  •        Add Defining Objects
This will give you a result window with a list of all the Complying Objects linked to the folder
The folder name will be added automatocally when you selet Use Starting Object.
You will see a count of found objects in the top of the results screen (including the folder you searched fom). Subtract 1 and you have your answer.
Mark
The easiest way is to highlight everything in the folder and select "Copy".
There is a counter in the bottom right corner of the Rich Client that will tell you how many objects you have in your clipboard.
A bit late, but at least in TC 10.1 you can right click in the toolbar down by the clipboard and check "Show Child Count Information":
Seems good TobbeP, we are on the move to TC10.1
Mr. TobbeP
Could you more detail for your suggest, it is same i have problem.
Thank you
Sudikin
Hi TOTOTC,
In TC10.1, if you right click in the toolbar down in the right corner of the main screen (where you have the clipboard):
You can as I described earlier, get a counter for the number of childs a parent got (e.g. a Folder):
Hope this make things a bit more clear  =)
Best Regards
TobbeP
Mr. TobbeP
Your suggest very clear and Solved.
Thank you VM
Sudikin
