Create JT from Journal.vb
Is possible to create JT from parts to Teamcenter by programing journal.vb in NX??
I have found information for create JT but outside Teamcenter (NXOpen.JtCreator()).
Thanks for all.
Re: Create JT from Journal.vb
I can only this (in NX11.0.0.33): create a JT file and upload it into the UGMASTER dataset.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.PDM
Module Module1
    '  Explicit Activation
    '      This entry point is used to activate the application explicitly
    Sub Main()
        Dim theUI As UI = UI.GetUI()
        Dim theUfSession As UFSession = UFSession.GetUFSession()
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Dim workPart As NXOpen.Part = theSession.Parts.Work
        Dim displayPart As NXOpen.Part = theSession.Parts.Display
        Dim export_folder As String = Nothing
        Dim managerActive As Boolean
        theUfSession.UF.IsUgmanagerActive(managerActive)
        If managerActive = True Then
            theUfSession.Ugmgr.AskExportDirectory(theSession.Parts.BaseWork.Tag, export_folder)
            lw.WriteFullline("Export Directry: " & export_folder.ToString)
            Dim partName As String = ""
            theUfSession.Part.AskPartName(theSession.Parts.Display.Tag, partName)
            Dim partNumber As String = ""
            Dim partRevision As String = ""
            Dim partFileType As String = ""
            Dim partFileName As String = ""
            theUfSession.Ugmgr.DecodePartFileName(partName, partNumber, partRevision, partFileType, partFileName)
            lw.WriteLine("Part Number " & partNumber)
            lw.WriteLine("Part Revision " & partRevision)
            lw.WriteLine("Part File Type " & partFileType)
            lw.WriteLine("Part File Name " & partFileName)
            '   Menu: File->Export->JT...
            Dim markId1 As NXOpen.Session.UndoMarkId = Nothing
            markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Start")
            Dim jtCreator1 As NXOpen.JtCreator = Nothing
            jtCreator1 = theSession.PvtransManager.CreateJtCreator()
            jtCreator1.IncludePmi = NXOpen.JtCreator.PmiOption.PartAndAsm
            jtCreator1.TessOption = NXOpen.JtCreator.TessellationOption.Defined
            jtCreator1.LighweightLabel = "JT_Facet"
            'jtCreator1.ConfigFile = "C:\Siemens\NX11\pvtrans\tessUG.config"
            jtCreator1.ConfigFile = theSession.GetEnvironmentVariableValue("UGII_BASE_DIR") + "\pvtrans\tessUG.config"
            'JT translate in one file
            jtCreator1.JtfileStructure = NXOpen.JtCreator.FileStructure.Monolithic
            jtCreator1.AutolowLod = True
            jtCreator1.TessOption = NXOpen.JtCreator.TessellationOption.Nx
            jtCreator1.PreciseGeom = True
            theSession.SetUndoMarkName(markId1, "Export JT Dialog")
            Dim listCreator1 As NXOpen.ListCreator = Nothing
            listCreator1 = jtCreator1.NewLevel()
            listCreator1.TessOption = NXOpen.ListCreator.TessellationOption.Defined
            listCreator1.Chordal = 0.001
            listCreator1.Angular = 20.0
            jtCreator1.LodList.Append(listCreator1)
            Dim listCreator2 As NXOpen.ListCreator = Nothing
            listCreator2 = jtCreator1.NewLevel()
            listCreator2.TessOption = NXOpen.ListCreator.TessellationOption.Defined
            listCreator2.Chordal = 0.001
            listCreator2.Angular = 20.0
            jtCreator1.LodList.Append(listCreator2)
            Dim listCreator3 As NXOpen.ListCreator = Nothing
            listCreator3 = jtCreator1.NewLevel()
            listCreator3.TessOption = NXOpen.ListCreator.TessellationOption.Defined
            listCreator3.Chordal = 0.001
            listCreator3.Angular = 20.0
            jtCreator1.LodList.Append(listCreator3)
            listCreator2.Chordal = 0.0035
            listCreator2.Angular = 0.0
            listCreator2.Simplify = 0.4
            listCreator2.AdvCompression = 0.5
            listCreator3.Chordal = 0.01
            listCreator3.Angular = 0.0
            listCreator3.Simplify = 0.1
            listCreator3.AdvCompression = 1.0
            Dim markId2 As NXOpen.Session.UndoMarkId = Nothing
            markId2 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Export JT")
            theSession.DeleteUndoMark(markId2, Nothing)
            Dim markId3 As NXOpen.Session.UndoMarkId = Nothing
            markId3 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Export JT")
            'jtCreator1.OutputJtFile = "C:\Users\Administrator\AppData\Local\Temp\027493__A____1\.jt"
            Dim nXObject1 As NXOpen.NXObject = Nothing
            Try
                ' Invalid file name
                nXObject1 = jtCreator1.Commit()
            Catch ex As NXException
                ex.AssertErrorCode(640005)
            End Try
            theSession.UndoToMarkWithStatus(markId3, Nothing)
            theSession.DeleteUndoMark(markId3, Nothing)
            Dim markId4 As NXOpen.Session.UndoMarkId = Nothing
            markId4 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Export JT")
            theSession.DeleteUndoMark(markId4, Nothing)
            Dim markId5 As NXOpen.Session.UndoMarkId = Nothing
            markId5 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Export JT")
            theSession.DeleteUndoMark(markId5, Nothing)
            Dim markId6 As NXOpen.Session.UndoMarkId = Nothing
            markId6 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Export JT")
            jtCreator1.OutputJtFile = export_folder.ToString + "\" + partNumber.ToString + "_" + partRevision.ToString + ".jt"
            Dim nXObject2 As NXOpen.NXObject = Nothing
            nXObject2 = jtCreator1.Commit()
            theSession.DeleteUndoMark(markId6, Nothing)
            theSession.SetUndoMarkName(markId1, "Export JT")
            'jtCreator1.Destroy()
            Dim thePDMSession As NXOpen.PDM.PdmSession = theSession.PdmSession()
            Dim fm As NXOpen.PDM.FileManagement = thePDMSession.NewFileManagement
            Dim itemids() As String = {Nothing}
            Dim itemrevisionids() As String = {Nothing}
            Dim datasetnames() As String = {Nothing}
            Dim datasettypenames() As String = {Nothing}
            Dim datasetrelationtypenames() As String = {Nothing}
            Dim datasettoolnames() As String = {Nothing}
            Dim filetype() As Boolean = {Nothing}
            Dim namedreferencednames() As String = {Nothing}
            Dim importfilenames() As String = {Nothing}
            Dim importdirectorynames() As String = {Nothing}
            itemids(0) = partNumber
            itemrevisionids(0) = partRevision
            datasetnames(0) = partNumber.ToString + "-" + partRevision.ToString
            datasettypenames(0) = "UGMASTER"
            datasetrelationtypenames(0) = "has shape"
            'datasettoolnames(0) = ""
            'filetype(0) = True
            'namedreferencednames(0) = ""
            'importfilenames(0) = jtCreator1.OutputJtFile.ToString
            importdirectorynames(0) = export_folder
            lw.WriteFullline("JT: " & jtCreator1.OutputJtFile.ToString)
            'NX 11.0.2 create dataset
            'fm.ImportFilesAndCreateDatasets(itemids, itemrevisionids, datasetnames, datasetrelationtypenames, datasetrelationtypenames, datasettoolnames, filetype, namedreferencednames, importfilenames, importdirectorynames)
            fm.ImportFiles(itemids, itemrevisionids, datasetnames, datasettypenames, datasetrelationtypenames, importdirectorynames)
        End If
        '   Menu: Tools->Journal->Stop Recording
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
        '----Other unload options-------
        'Unloads the image immediately after execution within NX
        'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
        'Unloads the image explicitly, via an unload dialog
        'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly
    End Function
End Module
Modify the TC preference to see this JT in the Viewer tab:
TC Pref.jpgTC Pref
The demo video:
(view in My Videos)
Attila Szepesi, Application Engineer, graphIT Ltd.
Production: NX12.0.2 | TcUA 11.3
Development: VB.NET, C# Testing: NX--
Hi @ManuSendon,
File > Save > Save Options > Save JT Data.
Is there any particular requirement to create JT using VB journal?
