Create Revisable Dataset
Hello All,
Is it possible to create a revisable dataset?  If so, has anyone done this before?
Thanks in advance!
Jake
Re: Create Revisable Dataset
Not sure what you mean? A Dataset is a container for files (can be multiple named references and extensions) that is versioned. By default, three versions are retained. Not all Dataset types support versioning. Revisioning is handled by the Item Revision.
Evaluating: AW 3.4
@RandyEllsworth
I want to be able to revise, assign a naming convention, and control a dataset in the same manor you would an item revision.  There doesn't appear to be any way to manage document control such as MS application documents.  Ideally, I would like to be able to create, revise, and custom name for example a word document, and then associate it with an item revision.  If that makes any sense.
Jake
You may want to look at Document Item type for the MS Word case. It is specifically designed to handle document revisions. See posts by Trish Laedtke on Content and Document Management.
Evaluating: AW 3.4
