Create and attach a dataset or item during a workflow.
I would like to know there is a way we could create an instance of a dataset or an item during a workflow and attach to the item revision on which the workflow is running. I know that we can create a form and attach it to the target item revision in a workflow, is there any handler to do the same for a dataset or an item?
Thanks and Regards
Sanket Pusalkar.
