Create dataset business object in BMIDE to store STEP files in TC
Experts,
I want create a custom dataset business object to store .STEP file in Teamcenter
I have solid edge integrated with Teamcenter, Is there a way to select SE tool for edit while creating new Business object dataset?
Rafa
5 REPLIES 5
Re: Create dataset business object in BMIDE to store STEP files in TC
If you set SE integration template as one of dependent template, you may be able to use the data model elements (disclaimer I have not tried this though)
Be aware that SE integration owns that template, so they are free to change that in future versions..
Thanks for the repsonse. I will give a try and will let you know the result
Rafa
I have added SE integration template as dependent template and I see these options
Do you think SEassembly would work?
Rafa
Without knowing the intent, it is difficult to say which tool would work..
Need to store the step files and opens it when you double click that on the dataset.
Rafa
