Creating a document library
Builder
Builder
Hi all.
I want to cerate a library of whitepapers with classified read permissions in TC. Users should have just read permissions on different groups of PDF documents. Actually the count of documents are more than 3000, so I need to make a batch or automatic import job to different groups.
1. Could anyone please suggest me the best approach?
2. Which module should be used and How?
Re: Creating a document library
Builder
Builder
Any comments or suggestions appreciated.
Good afternoon, try to look at Authorized Data Access (ADA License), perhaps this is what you need. I'm attaching a document, it's not very new, but maybe it will help you.
If you need to import 3000 files into Teamcenter. Take a look at the following commandline utilities.
The full usage is discribed in "utilities_reference.pdf" in the teamcenter documentation
  1. ps_upload
  2. import_file
