Custom Release Status Icon does not render in Tc 11.4 RAC ?
Hi Experts,
I want to add a custom release status icon beside the item revision
I have followed a known method
Created a file customer.properties  in TC_Root\portal\plugins\configuration_11000.2.0
The file contains information defined as:
release_status_list.WFRejected.ICON=images/WF4Rejected.png
The picture is 16x16 pixels and a .png file
WFRejected is display name for the status
Then I created an images folder in the same configuration_11000.2.0 directory and placed the WF4Rejected.png
Cleared RAC Cache and restart all the servcies, run the genreg.xml file.
I still don't see the Red flag appending, Does anybody see the same issue in Tc 11.4?
Rafa
54 REPLIES 54
Re: Custom Release Status Icon does not render in Tc 11.4 RAC ?
You need to use the Display Name instead of the Real Name in the properties file. Make sure to escape any spaces in the Display Name with a backslash. Run genregxml after changing the properties file.
Evaluating: AW 3.4
Oh, you already addressed that and it is showing correctly UNDER the Item Revision. You need another line in your properties file...
release_status_list.Obsolete.ICON=images/ACME4ff0000circle.png
release_statuses.Obsolete.ICON=images/ACME4ff0000circle.png
The release_status_list is for under the IR
The release_statuses is for next to the IR
Evaluating: AW 3.4
I'm in too much of a hurry and put the values backwards. Here's the full story...
# ACME Status Icons
# Description
# Custom icons for Item, ItemRevision and Datasets are now in BMIDE.
# release_statuses callouts are replaced in BMIDE with a ReleaseStatusMap
# (ACME4ReleaseStatusMap).
# Release status objects
# Next to ItemRevision - use release_status_list format
# Under ItemRevision - use release_statuses format
# Hex Colors
# ff0000 Red
# ffa500 Orange
# ffff00 Yellow
# 00ff00 Green
# 0000ff Blue
# a020f0 Purple
# 4b0082 Indigo
# ee82ee Violet
# ffffff White
# bebebe Gray
# 000000 Black
# Example (USE DISPLAY NAME)
# release_status_list.Blue\ Flame.ICON=images/ff0000flag.png
# release_statuses.Blue\ Flame.ICON=images/ff0000flag.png
Evaluating: AW 3.4
Hi @RandyEllsworth,
Thanks for the quick response.
I have used release_status_list and release_statuses in the properties file as you mentioned and run genregxml before testing it.
I also created property render in BMIDE
Render definition
<?xml version="1.0" encoding="UTF-8"?>
<icons Version="1.0">
<propertyMap name="ReleaseStatusMap">
<item key="WFRejected"      value="WF4Rejected.png"/>
</propertyMap>
<primaryIcon source="object_name" mapName="ReleaseStatusMap"/>
</icons>
Attached Property renderer
ReleaseStatus.object_string
But I still see no custom status is attached next to Item revision and I am able to get it under Item revision like below
Rafa
It's likely that the BMIDE ReleaseStatusMap is overriding the customer.properties file. Did you import the icons into BMIDE, Icons\master_icon.xml (shown in Navigator)? And they match case WF4Rejected.png (and not PNG or other).
Evaluating: AW 3.4
Hi @RandyEllsworth
Yes, I did imported the icons to BMIDE
I tried only the BMIDE way to append the status next to IR, it did not work but I am able to add custom status under the IR
Rafa
Your configuration looks okay to me. The BMIDE Property Renderer is obviously having some problem that I'm not able to spot except that I use object_string instead of object_name. You can try changing the Property Renderer to say object_string and that may fix it or you'll need to delete the Property Renderer and let the customer.properties file be king.
</propertyMap>
<primaryIcon source="object_string" mapName="ReleaseStatusMap"/>
</icons>
Evaluating: AW 3.4
Thanks @RandyEllsworth!!
I will try the below approach and will post you the result.
Rafa
Hi @RandyEllsworth
Tried Four different cases:
1.Tried with changing the Property Renderer to "object_string" and kept customer.properties file- Did not work ( No custom status under IR and next to IR)
2.Deleted Property render from the BMIDE and kept customer.properties file with release_status_list and release_statuses - Did not at work ( No custom status under IR and next to IR)
3.Added BMIDE property render and deleted customer.properties file ( I can see custom status under IR and no status next to IR)
</propertyMap>
</icons>
4.Added BMIDE property render and kept customer.properties file with release_status_list and release_statuses ( I can see custom status under IR and no status next to IR)
I see customer.property file isn't working at all in my RAC.
Rafa
