Re: Custom Release Status Icon does not render in Tc 11.4 RAC ?
That's strange behavior. I can use the customer.properties file for both status icons (next to and under). And I can use the PropertyRenderer for next to and customer.properties for under. Both methods work for me (Tc11.4).
Evaluating: AW 3.4
Does your customer.properties file start with a comment line?
Try
# Whatever nonsense you want goes here
release_status_list.WFRejected.ICON=images/WF4Rejected.png
@jonathan_morris
I did added comment line on customer.properties file
But still no luck :(
Rafa
When you run genregxml are your RegistryLoader_<lang>.xml.gz files in portal/registry definitely being updated?
When I first tried what you are doing I had the situation where the contents of customer.properties weren't being included into the RegistryLoader xml file, but I can't seem to get it to fail to include the values now.
You could try moving the old .xml.gz files out of the way, and try genregxml to make sure they are generated from scratch.
@jonathan_morris
Yes, I did tried it now
I see it the new RegistryLoader_<lang>.xml.gz files got created but no custom status next to IR
Rafa
@Rafa2 - can you share a screenshot of your images folder? You are sure that the png files are in that folder and named correctly? Seems everything else you have set correctly.
Jamie
Jamie Griffis | PLM Solution Architect | Engineering USA
@Jamie_Griffis Here it is
Rafa
@Rafa2 - this is a tough one. Is your locale English?
@Jamie_Griffis
Yes, it is English.
Even I am finding it strange, for some reason its not liking it.
Rafa
Can you show the file extension for your images in the image directory please? I think they say PNG instead of png?
Evaluating: AW 3.4
