Re: Custom Release Status Icon does not render in Tc 11.4 RAC ?
@RandyEllsworth
I could see .png as file extension
Rafa
Now you have file extensions turned on is your customer.properties file really a customer.properties, not e.g. customer.properties.txt?
Can you post the file just in case it's something strange, then I can try it on a system of mine?
I'm with @Jamie_Griffis and @RandyEllsworth.  It looks like you've done everything right.
@jonathan_morris
It is customer.properties file, I have attached the file with .txt extension as it is not allowing me to upload properties file
Rafa
I'd try a few more things... delete the RAC folder, run the genregxml.bat again. Did that work? If not, try to log into the computer as a different user. Try it on a different computer. Any luck? That is all the ideas that I have left. If you can't resolve it with that, then it is time for Gtac to get involved.
Jamie
Jamie Griffis | PLM Solution Architect | Engineering USA
@Jamie_Griffis
I cleared RAC cache and ran genregxml.bat for every test.
I did not try with diff user though, let me give it a shot at it
Rafa
Make the icon 16x16 pixels in size, and give the image a transparent background?
@Rafa2, please attach your PNG for @jonathon_morris too.
Evaluating: AW 3.4
@jonathan_morris
Attched is the custom icon
Icon is of 16x16 pixels in size and it has a white background
Rafa
@jonathan_morris
I have installed a new instance of Teamcenter, 11.5 and I see it is working with no issues
Do we have to perform the same configuartion for every client machine to get it work on 4-tier or do we have any BMIDE approach to append custom release status next to Item revision?
Rafa
Hi @Rafa2,
    Yes, you need to deploy the configuration to each of the clients.
    For customers that have a lot of clients they normally build a client image, and push it to all their clients via whatever software distribution system they use for everything else, rather than going around each client individually.
    I take it that we were unable to find a resolution to the issue with 11.4?
@jonathan_morris
Yes, strange that instance is not responsive to release_status_list.
I might give a try in Production which is 11.4 and see how it works.
Thanks for help again!!
Rafa
