Custom properties for a Dataset type
Experts,
I want to create custom properties related only to a dataset type. However, BMIDE allows only runtime properties as it's a secondary object.
How to create 'persistent' custom properties ?
Re: Custom properties for a Dataset type
You must designate the specific dataset type as primary type - you then can add persistent properties to the new primary type.
thanks @arenney for your response.
We have datasets as secondary objects in our project since long. There is definitely some reason for this, which I am not aware of. So the primary type option is ruled out.
But I'd like to know the difference in behaviour of datasets as primary and as secondary objects. Do you have an idea ?
