Customize File->New->Item dialog box
I have 2 different sites, A & B. B is a new site which I'm trying to replicate from A(without a db refresh).
In Site A, when I select File->New->Item, below dialog box appears:1.JPG
In SiteB, when I select File->New->Item, below dialog box appearsSmiley SadNotice the difference in layouts)2.JPG
The subsequent layout also are diferent from each other.
I now need to have SiteB to display as SiteA. I copied all plugins from A to B, ran registry, even then the layout doesnot change. There are also no customized stylesheets.
Can someone point me the exact thing I need to do to achieve my target?
Thanks in advance.
Re: Customize File->New->Item dialog box
Do you use the same version of Teamcenter on both sites?
Siemens Genius Siemens Genius
Siemens Genius
If your Teamcenters are the same version then does site A have the preference TC_Enable_Legacy_Create defined?
Site B may not have the preference, or it may be set to "No Value".
Thanks @jonathan_morris. The preference was the issue. Adding 'Item' to the preference, I was able to get the layout.
Siemens Genius
Great.  You may also want to check TC_Enable_LegacySaveAs.
