Customize Toolbar
Have you an idea what preference you set if you customize toolbar (See screenshot).
Thank you for your answer
4 REPLIES 4
Re: Customize Toolbar
Good afternoon, this is done using the toolbar configuration. Right-click on the toolbar -> Customize toolbar, add the necessary commands from the menu
Thank you.
if  you right click  on the toolbar -> Customize toolbar you know what preference is active because i want to put in my configuration.
Good afternoon, I do not think you can manage this using preference in Teamcenter. I think the Toolbar settings are saved in somewhere in the
C:\Users\your_user\Teamcenter\RAC
Correct @ArthurRM. The Rich Application Client (RAC) modifications are client specific and saved as "cookies". The default location for cookies is %USERPROFILE%\Teamcenter\RAC\<datetime>\.metadata\.plugins\
And you likely want to view the xml files in com.teamcenter.rac.toolbar.customization\*.xml
The cookies keep track of menus, window size and location (X, Y), things like that.
Evaluating: AW 3.4
