Customize the Launch Pad but not work as designed
Following the document step by step:
https://docs.plm.automation.siemens.com/tdoc/tc/11.3/help#uid:xid1256877:index_programmers_guide:id1...
In the step3,i can't find the definitions for file elements used in the Launch Pad XML file under "TC_ROOTportal\plugins\com.teamcenter.rac.launchpad\schema" directory.
The step7 also confused me.Need more details or an example.
Is there anyone done this before?
Any suggestions will beappreciated,thanks!
