Data model deployment
Is there any way to do automatic data model deployment? I have to do deployment again and again, then I need to go throught all "Next" buttons and do some selections\updates. So is there any way that we could automate deployment(may be throught some batch file where I will just change to custom template path and it will go through)?
Rupesh
Re: Data model deployment
A batch deployment is not supported OOTB. What you can do is to grep the commands from the log file and put them in a batch script. This should work but is just recommended for repeating data model deployments in a test environment.
xtof
