Database instance size requirements for Teamcenter
Where can we find the database instance size requirements for Oracle and MS SQL ?
Colleagues from IT dept want to know this to configure a DB for sandbox testing environment.
6 REPLIES 6
Re: Database instance size requirements for Teamcenter
Not aware for MSSQL, but for oracle it will show while installing the instance, please find the attached snapsdb1.PNGdb2.PNG
@GaneshDasmalethanks for your reply.
Probably my question is misleading. I wanted to know:what is the 'required' size of DB instance for Teamcenter  environment ? Does Simens provide any guidelines for this, just like they provide size of RAM/disk space required ?
Negative. Every customer uses Teamcenter slightly differently depending on their business rules and processes which results in different DB instance sizing. Best practice is to let the installer (TEM) create the instance with auto-growth. You can manually create the instance ahead of time by running pre-defined scripts located in the media. There isn't a required sizing. And afaik, they don't provide RAM/disk sizing requirements either for exactly the same reason. They provide recommendations?
Evaluating: AW 3.4
@RandyEllsworth:Thanks for your response. Good to know about the best practice for DB instance creation and auto-growth option, which I didn't know before.
I actually wanted to say "they provide disk space requirements for Teamcenter installation" (as in the attached image).
Then in that same vein you could say they provide DB instance disk space requirements in the db creation scripts. See:
BASEMEDIA\tc\db_scripts
PATCHMEDIA\tc\db_scripts
Evaluating: AW 3.4
There is no required size for Teamcenter databases, since they grow with the amount of objects stored.
The DB size has been growing to above 60 GiB within the last ten years for us.
You may want to optimize the DB file size periodically to get rid of unused space.
Employees of the customers, together we are strong ;)
