Date Format about Audit Reports
Hi, guys.
 Using Report Builder Reports to generate “Audit - General Report” and get the following report.
The Logged Date shows like this “2017-07-25T05:19:15Z” .However,that is not the  local Server time.
Is there any way to show the local Server time? For me,it shoud be 2017-07-25 10:19:15
Any suggestions will be appreciated~
Thanks!
Re: Date Format about Audit Reports
Greenwich Mean Time (Zulu) so that all events across server logs will have similar timestamps for reconstructing transactions and responses. I don't know how to break that functionality by showing "local" time.
Evaluating: AW 3.4
You might be able to address this issue with the report stylesheet. I haven't tried it, and I don't know if the Teamcenter XSLT parser supports it, but you could try using the adjust-dateTime-to-timezone function to change the date and time reported by Teamceneter to your local timezone. Take a look at this website for more information:
http://www.xsltfunctions.com/xsl/fn_adjust-datetime-to-timezone.html
Arden Bedell | Teamcenter Wonk | Applied CAx, LLC
