Ddefault version to display in teamcenter
May I know what is the preference to set to display number of versions to each dataset. We have set AE_dataset_default_keep_limit as 20 (we know it hits volume) but for each dataset it is displaying max 10 in the drop down. I need to change the preference to display the versions as per set. Please advise.
Re: Ddefault version to display in teamcenter
I think you have to make that change in BMIDE? Dataset > Main (tab) > Business Object Constants (tab) > Display Name, Edit...
Change the Value (string) to change the Dataset name.
Evaluating: AW 3.4
