Debugging eclipse plugin (RAC customization) with breakpoints
I have an eclipse project (not developed by me) and want to debug the same. The plugin contains a custom application(perspective).
I set breakpoints in eclipse and started debug using Menu: Run -> Debug Configurations... -> Select TC RAC as target platform -> Debug.
After this RAC is launched, I logged in and executed custom menus, but I do not see the cusrsor stopping at any breakpoint.
Any suggestions/tips would help! Thanks.
Re: Debugging eclipse plugin (RAC customization) with breakpoints
Switch to Debug perspective in Eclipse after RAC starts.
Arden Bedell | Teamcenter Wonk | Applied CAx, LLC
