cancel
Deep Copy rule based on a relation property
Hi
Is it possible to write a Deep Copy Rule condition that will check a property value on a relation to determine whether to copy the relation on revise?
Peter
Re: Deep Copy rule based on a relation property
I have not tried it in my Teamcenter...but a thought:
May be you could create a compound property on primary object out of relation property and then check for it in the deepcopyrule condition..not sure if this would work
Best Regards
Harish
