DeepCopy Rules
Dear Listers, I have created the following Deep Copy Rule and attached to the Custom ITem. The intention is ensure that when ever the Item attains a status of Obsolete I do a copy on the Item and it is copied as an object. In the out of the box scenario on Teamcenter 10.1.7 how would I configure this to ensure that the copy is possible only when the status on the Item is obsolete. Regards Vilas
Re: DeepCopy Rules
You will have to set up a condition that looks at the release_status_list property of the item revision, if that's possible.
Arden Bedell | Teamcenter Wonk | Applied CAx, LLC
