Re: Deployment UNC path
Active Workspace is the ONLY zero-install option. All others require some level of installation on the client, including the shared deployment method, which I personally avoid. For now, I've batch scripted the TEM silent installation and run this, as administrator, on each client that needs the software.
Between the two - no. But other ports that need to be opened in the firewall - certainly. There are lots of ports to think about and allow through the firewall.
Here's some from tc help but its not a clear list...
https://docs.plm.automation.siemens.com/tdoc/tc/11.5/help/#search:page=1;rpp=10;query=ports
Here's some from GTAC but its not a clear list...
https://solutions.industrysoftware.automation.siemens.com/result.php?sort=desc&q=firewall+%26+port&p...
Evaluating: AW 3.4
