Deployment center
Hello;
I started to use DC 2.0 , I have some issues here:
1.in Database server parameters I can't see a "database Name" parameter
2.I added some components to my env but I want to remove them from env before starting to deploy it, how I can do this?
BR.
4 REPLIES 4
Re: Deployment center
It won’t let you change the database name. If it’s not “tc” then AWC won’t work. You’ll see that mentioned elsewhere on the boards.
Yes, you can remove components if you’ve never ran the batch scripts. Once I can pull it up later, I’ll get screenshots.
Jamie
Jamie Griffis | Teamcenter Architect | Applied CAx, LLC
If I run the batch file, I must change the enviroment components from Tem, yes?
BR.
If you want to remove features after you've installed it with the batch file, I believe so. Then you'd reregister the environment back to DC so that it has your current configuration.
To remove the component via DC before using the scripts, just select the component and hit the icon that is a circle with a minus sign. See screenshot.DC.png
