Disable assign button in Teamcenter
Do you know what preference I can use to disable the assign button  in Teamcenter?
Thanks.
9 REPLIES 9
Re: Disable assign button in Teamcenter
There is no single preference for disabling the "Assign" button in the Item creation wizard. There is a process for making the Item ID and Rev ID read-only in the create dialog but its much more involved.
It starts with preferences:
ASSIGNED_ITEM_ID_MODIFIABLE=0
ASSIGNED_ITEM_REV_MODIFIABLE=0
In the ItemCreate stylesheet: append 'modifiable="false"' to properties item_id and revision:item_revision_id.
In BMIDE:
Set the Enabled property constant to "False" for Item.item_is and ItemRevision.item_revision_id.
Set the Modifiable property constant to "Read" for Item.item_is and ItemRevision.item_revision_id.
Ensure that you have a Naming Rule created that will populate those fields then deploy and test.
Evaluating: AW 3.4
Thank's for your answer.
I learned, we can use the "ITEM_autogenerate_id" preference to disable.
What do you think?
The ITEM_generate_id site preference was used before Tc10.1 to auto populate the Item Id. It's not supported in the current item create panel. Today, we use naming rules in BMIDE.
Evaluating: AW 3.4
There is another simpliest way - use naming rules for item_id/rev_id (customized by BMIDE) - activating naming rule automatically disable the Assign button
Can you to tell me how to activate naming rule?
Hi Alex,
Alternatively do you know how to keep the assign button active one a naming rule has been applied ?
@Cox_Matt wrote:
Hi Alex,
I thnik it may depend on a kind of naming rule you have applied. If naming rule based on counters may be assign button  remain active. But in   my case  I have regular expression without counter in my naming rule,so the Assign button was not visible
@Cox_Matt wrote:
Hi Alex,
The preference mentioned above - ITEM_autogenerate_id - does this job. you have to remove the item type for which you want to prevent auto-generation from the list of preference values, then Assign button gets enabled.
@Iqzas wrote:
@Cox_Matt wrote:
Hi Alex,
I dont have any values for ITEM_autogenerate_id preference and assign button doesnt appear.
So I think it's not a solution
