Disallow revision if change item aren't created
Hi everyone, I have a question about revision and change management.
I would like to disallowed users to revise item revision, if they have a certain status, without doing a change process (PR/ECR/ECN).
My first guess was to use the ACL but I'm wondering if there isn't an easier way.
Thank you in advnce,
Best regards,
Benjamin
Re: Disallow revision if change item aren't created
I wish but there is no straight forward way to do that.
Depending on how Teamcenter CM is set up (BMIDE CM conditions), I think you would require a bit of customization too to ensure that an item revision is allowed for revision if it is part of an 'active' (not the one already dispositioned and closed) change object impacted items and/or problem items.
Harish
