Dispatcher Client error: Access Denied
I installed TC11.4 Dispatcher and the services started successfully.
But as soon as I start a translation request, disp client throws error:
java.lang.Exception: java.security.GeneralSecurityException: Access Denied - please check the Access Rules for correct configuration or contact your administrator.
Any idea where's the problem ?
Re: Dispatcher Client error: Access Denied
Ensure that you have granted dcproxy (unless you used a different name) ACL privileges.
https://docs.plm.automation.siemens.com/tdoc/tc/11.4/help/#uid:xid354200
Yes I have done this. Translation request is created and it is stuck at INITIAL stage
You probably need ACL rules for the specific dataset type. Which translator are you calling? Does the zip translator work?
tozipfile is also not working. Scheduler and Module don't show any messages. DC gives following:
2018-03-09 16:20:56,640 INFO - Connected to Scheduler on Url rmi://localhost:2001
2018-03-09 16:20:56,641 DEBUG - TranslationUtil inititialized.
2018-03-09 16:20:56,641 DEBUG - Initialized file server with properties.
2018-03-09 16:20:56,642 DEBUG - User id : 1520590147706
2018-03-09 16:20:57,647 DEBUG - Property for SchedulerListener.Port is not specified. Using unused port 2600
2018-03-09 16:20:57,657 DEBUG - TranslationTaskManager instantiated
2018-03-09 16:20:57,657 INFO - Scheduling request state management task. Interval in minutes: 30
2018-03-09 16:20:57,658 DEBUG - inStates:
2018-03-09 16:20:57,659 DEBUG - CANCELLEd
2018-03-09 16:20:57,660 DEBUG - DELETe
2018-03-09 16:20:57,660 DEBUG - outStates:
2018-03-09 16:20:57,660 DEBUG - CANCELLED
2018-03-09 16:20:57,660 DEBUG - DELETE
2018-03-09 16:20:57,661 INFO - Start processing requests in database.
2018-03-09 16:20:57,661 DEBUG - Scheduling database relogin. Interval in minutes: 1440
2018-03-09 16:21:58,659 ERROR - Access Denied - please check the Access Rules for correct configuration or contact your administrator.
2018-03-09 16:21:58,659 INFO - Stopping Service...
2018-03-09 16:21:58,729 DEBUG - DC Server OUT - ******************************************************
2018-03-09 16:21:58,729 DEBUG - DC Server OUT - * *
2018-03-09 16:21:58,730 DEBUG - DC Server OUT - * The Teamcenter Server is shutting down *
2018-03-09 16:21:58,731 DEBUG - DC Server OUT - * normally... *
2018-03-09 16:21:58,741 DEBUG - DC Server OUT - * *
2018-03-09 16:21:58,741 DEBUG - DC Server ERR -
2018-03-09 16:21:58,741 DEBUG - DC Server OUT - ******************************************************
Are you using "dcproxy" or have you changed it to some other name? Where in the Org tree does user "dcproxy" currently reside (Group/Role)? You should get tozipfile working before attempting others.
https://docs.plm.automation.siemens.com/tdoc/tc/11.4/help/#uid:Translation_Server_Troubleshooting
https://docs.plm.automation.siemens.com/tdoc/tc/11.4/help#uid:xid1256815:index_plm00072:id262996
Thanks you!! The tip to create ACL rules helped.
I actually created a single ACL with hasClass(Dataset), with which all translations are working.
