Document properties on watermarks
Hi all,
I'm able to make watermarks and to display system properties on it or a defined string.
I saw that it should be possible to display properties of the item on which the watermark will be created.
I tried but didn't succeed. I made this configuration in the BMIDE (see attachments) and I'm using the following template :
<!-- PDF edit commands -->
<cmd:commandInputs>
<!-- add a text watermark -->
             <cmd:watermark>
             <cmd:text>Test_Watermark on \DateAndTime</cmd:text>
             <cmd:font>TimesNewRoman</cmd:font>
             <cmd:rotation>
             <cmd:lowerLeftToUpperRight/>
             </cmd:rotation>
             <cmdSmiley Surprisedpacity>0.2</cmdSmiley Surprisedpacity>
             </cmd:watermark>
</cmd:commandInputs>
Thank you in advance for your help,
Sènan
