Does IPEM import utility imports the data from Sub-folder?
I am trying to import a data using IPEM Import Utility. Data is stored in multiple sub-folders under one root folder.
Is there a way IPEM utility can be configured to provide the root folder location only and instruction file will contains all the paths for actual file - will that work ?
In a nutshell,
1. does IPEM import utility imports the data from Sub-folder?
2. can I use "config.pro" option in creo to provide a search path - does that takes into consideration?
Any help will be much appreciated.
Thanks!
Harshal
Re: Does IPEM import utility imports the data from Sub-folder?
Siemens Genius Siemens Genius
Siemens Genius
IPEMIMPORT is not really designed for mass migration.  It will work, but you need to resolve any issues with everything first.
Instruction files are the way to provide more control and load what you want.
What problem are you really trying to solve? How much data do you need to load and what do you want to do with it once loaded?
- Peter Heath - PLM Business Development Manager
ITI - Siemens Development and Solution Partner
