EPM Notify Handler
Hello Team,
I have systematically the error on EPM notify handler if i put the handler in start in task.
I used Review task. Think you it's the ACL problem. Thanks
5 REPLIES 5
Re: EPM Notify Handler
What arguments have you set for the handler?
Rich
Richard Bennett
PLM Consultant
www.ProspectPLM.co.uk
Thanks for your response.
Here are arguments that i used
I cant see the attachment....
Richard Bennett
PLM Consultant
Thanks.
I have some itemRevision, Item and Dataset in target  (See ScreenShoot)
I don't know what the issue is, but here is what I would do.
1 - Check the syslog.  This could hold more information as to what ow why Access is denied
2 - I dont know if the value for -url "rich,activeworkspace" is valid.  The documentation says either rich or activeworkspace.  What you have might be right, but I would try just having 1 value or the other just to prove its not that.
Richard
Richard Bennett
PLM Consultant
