EPM-set-property: How exactly it's work to remove value
Hi everybody,
I don't understand exactly how it's work with the handler: EPM-set-property
My idea if we demote the workflow, I add a step to delete some values.
I try with EPM-set-property
-property       bus4_approver_name
-value             $empty
-bypass
but it doesn't work, I need to attach the target or something like that!
Can you help me?
Thank you
PLM Technical IT
Re: EPM-set-property: How exactly it's work to remove value
Looking at the examples in the documentation, I think you need to add the -to_attach argument so that the property change is made to the target of the workflow:
-value             $empty
-to_attach     TARGET
-bypass
Just keep the -value argument without any argument value.
Hello everybody,
sorry other major tasks arrived on my desk! I will test ASAP your solution and give a quick answer.
Thank you already for your idea and answer and help Smiley Wink
Best Regards
PLM Technical IT
Hello, with not value! It's working.
Really thank you
PLM Technical IT
