EPM-set-task-result-to-property on a Release_status_list
Hi everybody,
since I know this handler, it's really helpful to a lot of case in my company.
Now, I have a question for all of you specialist.
I would work on status! If it's status 60, you go to the way 1, if it's another status you go to the way 2!
I need really to write all status into the way 2?
Thank you
PLM Technical IT
Re: EPM-set-task-result-to-property on a Release_status_list
I think you should write a query that returns item revisions with the release status of 60, then switch to EPM-set-condition in your condition task and use your new query to determine if the target item revision has a status of 60 or not. In this way you'll have a simple branch in your workflow where IRs with status 60 take one path and IRs with any other status take another.
Arden Bedell | Teamcenter Wonk | Applied CAx, LLC
Yes you're right!
I think, I need to work with this kind of queries.
Thank you for your answer
PLM Technical IT
