EXPORT Organization
What methods are available for me to export my organization structure
Lindy
15 REPLIES 15
Re: EXPORT Organization
You'll need DBA access...
Export organization:
plmxml_export -u=xxxxx -p=xxxxx -g=dba -xml_file=tc_person.xml        -class=Person
plmxml_export -u=xxxxx -p=xxxxx -g=dba -xml_file=tc_role.xml -class=Role
plmxml_export -u=xxxxx -p=xxxxx -g=dba -xml_file=tc_group.xml -class=Group
plmxml_export -u=xxxxx -p=xxxxx -g=dba -xml_file=tc_user.xml -class=User
plmxml_export -u=xxxxx -p=xxxxx -g=dba -xml_file=tc_groupmember.xml
-class=GroupMember
Evaluating: AW 3.4
If you are using Tc 11.2, Look at admin_data_export utility
Also look at dsa_util:
Distributes system administration data, such as users and groups, from one site to
another. When adding a new site, this allows you to enter the site information of all
sites in the network so the new site can exchange data with them.
Caution
Do not use this utility to share organization objects between sites if the same
organization objects are shared through a global organization.
Note
This utility should be used only for the initial migration of system objects.
Siemens PLM Software recommends that you do not use this utility to maintain
system objects.
Propagates Teamcenter administration data among multiple sites and allows
administrators to:
• Manage system data from a central site.
• Support non-networked sites.
• Create reports of the results of a distribution operation.
When i tried to export "Organization" thru' PLMXML export, it asks target sites, did not allow me to export.we have TC9
Are you using the plmxml_export utility as I described above or something else? I've never been asked for source/target sites using that util. If you're using dsa_util, it is designed for multisite and will ask for source/target.
Evaluating: AW 3.4
yes. it works. thanks
After you import Organization users through plmxml, does the password of user retained from the Origin site or do we need to modify the passwords?
Is there new method to export and import organisation groups and roles, I see plmxml and dsa_util as been depricated from TC11
Tried with admin_data_export but not able export groups
@VSKM What error did you get when trying to export organization using admin_data_export?
I am able to export the organization using the following
admin_data_export -u=cpoulson -pf=cpf.txt -g=Admin -adminDataTypes=Organization -outputPackage=C:\Temp\admin_data\admin_data_ORG_DEV_out.zip
