Re: EXPORT Organization
@VSKM, like @CraigPoulson, I'm able to export the Org including groups in tc11.4. And if you want a specific group only then try:
admin_data_export -u=infodba -p=***** -g=dba -adminDataTypes=Organization
-inputCriteria=Group{name=Engineering} -outputPackage=c:\temp\test.zip
BTW, the function in plmxml_export hasn't gone away, it still works. The NOTE just "suggests" that you use admin data.
Evaluating: AW 3.4
Specifically, this...
NOTE:
From Teamcenter 11.1.0 release -class option should not be used to export
administrative objects: User, Group, Role, Person, GroupMember, ImanVolume,
POM_inc, TC_Project, ProjectTeam, Discipline, ImanQuery, RevisionRule.
Please use admin_data_export/import utility as a replacement.
The plmxml_export with -class=Group still works.
Evaluating: AW 3.4
Hi @RandyEllsworth
I have used same input suggested by you, after exporting I got entrire organisation, which i dont want.
admin_data_export -u=infodba -p=infodba -g=dba -adminDataTypes=Organization
Meanwhile, I also used PLMXML to export group, it is working.
I can validate that I'm getting the whole organization as well using that command syntax. I've tried a few different iterations but have not been able to export a single Group.
Evaluating: AW 3.4
Have you tried exporting partial admin data using TEM?
https://docs.plm.automation.siemens.com/tdoc/tc/12.2/help#uid:xid900316
Evaluating: AW 3.4
Hi @RandyEllsworth
Tried exporting through partial admin data using TEM
I thing we can use exprot partial admin data to export singal group from organisation
