Engineering utiliy Exception:POM002
I'm trying to install Teamcenter 12 a lot of time but it always..Capture.JPG
Please, help to resolve this issue. Thank you.
Here is my log file.
Re: Engineering utiliy Exception:POM002
Any hint from License Log?
There doesn't appear to be a problem with the database. Check for a E:\TC_ROOT\logs\1808081250\bmide_schema_XXXXXX.syslog...
It will tell you more about what happened.
Evaluating: AW 3.4
