Error (39014) occurred while performing a licensing operation
I am trying to upgrade from TC 8.3.3 to TC 10.1.6 on SunServer, it fails at step 50 of 179 complaining about some duplicate properties. So I am trying to remove those duplicate properties using command line utility "business_model_updater", but I get the below error:
"Error occured while performing a licensing operation"
I can login to Oracle database using sqlplus with infodba login.
If I try to run "list_users", I get a similar error:
Error (39014) : License usage record creation failed for the user infodba
ERROR - 2017/2/15-17:55:50.184 UTC - NoId - 39014 - Error (39014) occurred while performing a licensing operation. Please contact your Teamcenter administrator
Please let me know any ideas to fix this issue.
Ajay
