Error While save as from PartA to PartB
Hello Team,
While i am doing a save as from PARTNUMBER A to PARTNUMBER B In Teamcenter 11
I am Facing an error called "AbsOccurence" you can see the attachment for more information
Can anyone help me out to fix this error
Thanks in Advance :)
Akhilesh B R
4 REPLIES 4
Re: Error While save as from PartA to PartB
See PR#8527483 (some of the steps may help you). Are Bounding Boxes generated for child parts and weld points?
Evaluating: AW 3.4
Hello Randy
thanks for the quick response , and i am looking for the steps , can you please help with it
Akhilesh B R
Randy suggested that  you look at PR#8527483?  If you search the solution centre for '8527483' it takes you to this page:
https://solutions.industrysoftware.automation.siemens.com/result.php?sort=desc&p=1&q=8527483
Apologies if this isnt what you meant.
Richard
Richard Bennett
PLM Consultant
www.ProspectPLM.co.uk
Thanks a lot
Appreciate your response
