Error adding property table to IMM material
I'm trying to add a property table to an IMM material object. I've followed the procedure as outlined here: https://docs.plm.automation.siemens.com/tdoc/tc/11.2.3/help#uid:xid1256815:index_plm00071:id166856:x....
Basically, all goes well until I reach the last step: adding data to the table. When I click the Add New... button I get an error message "Cannot find the object type to launch the wizard."
Any experts that can help me debug my problem? I already searched for the error on Google, but no hits.
Re: Error adding property table to IMM material
I believe you've created custom tablerow object (fnd0TableRow as parent) and linked it within the table property.
If the BMIDE deployment went well, then you may want to check the stylesheet configuration (object set, properties etc) for custom tablerow.
Also I believe tablerow works only in Summary stylesheet.
Let us know if this helps.
Harish
