Error in accessing the Server Manager Administration Console
Hello !
I have been recieving this error message when i try to access the Server Manager Administration console.  We are using TC 10.1.3. Any pointers would be highly appreciated.
Teamcenter 10.1.7
TC Visualization 10.1.7
NX:11.02 | NX 9.02 | Catia V5 R2012 | AutoCAD 2018 | In-Context Editor |
Re: Error in accessing the Server Manager Administration Console
You are sure that the IIS server is started?
Are you getting this error after restarting them?
Other than that I have no idea..
Cem
This looks like an IIS/ASP.NET problem. Google may be your BFF. Several solutions are listed to get ASP.NET working:
http://forums.iis.net/t/1028546.aspx?ASP+NET+Configuration+HTTP+Error+404+3+Not+Found
https://support.microsoft.com/en-us/kb/942032
Best,
/Randy
Evaluating: AW 3.4
Cem,
The ISS was restarted and was recieving this error before the restart as well.
Teamcenter 10.1.7
Validate that JRE 1.7u17+ is being used. JRE 1.8u30 has issues (TcIF, Mapper and Server Manager Console).
Best,
/Randy
Evaluating: AW 3.4
Thanks for the response Randy, We are using JRE 1.7.60. So no cigar yet !!! Smiley Happy
Teamcenter 10.1.7
Is this a new install ?
I ran into the same issue after upgrading my TC10.1.4.0 to 10.1.4.2
After re-estating the Web.config from my backup copy of 10.1.4.0/tc/admin it works again.
( and the message is just saying it might be misconfigured ... ).
I am just wondering why that did not happen in my TESTING environment, only in Production ...
Thomas Zwatz, CADadmin, PÖTTINGER Landtechnik GmbH
Production: NX11.0.2.7 MP4 + TC10.1.7.1
Testing: NX11.0.2.7 MP4 + TC10.1.7.1
Development: C#
No, This is not a new install. This was working fine and i am not sure why or what caused this to happen.
As a last resort we did re-install the web tier and still have the same issue !!
Teamcenter 10.1.7
