Error install TCRS 12.0 : " Setting up the foundation data model failed"
Dear All
I installed TcRS 12.0 but have some error can't fix
the error description " Setting up the foundation data model failed"
Any body can help, please see log file in the attachment
Vietbay CO., LTD VN
Re: Error install TCRS 12.0 : " Setting up the foundation data model failed"
Good afternoon, judging by your logs, you have problems connecting to SQL Server:
ERROR - 2018/08/01-03:53:17.406 UTC - NoId - Connection to the database failed with :0 - Teamcenter.POM at d:\workdir\tc12w0710_64\src\foundation\pom\eim\eim_trans_util.cxx(936)
ODBC error. SQLSTATE: 28000 Native error: 18456
Message: [Microsoft][ODBC SQL Server Driver][SQL Server]Login failed for user 'Administrator'.
Approx SQL was "CONNECT"
ODBC error. SQLSTATE: 01S00 Native error: 0
What credentials did you enter to connect to the database?
Connect failed (18456) for 'Administrator' at A@DATABASE=tc;SERVER=Tech04,1433
Try using "infodba" instead of "Administrator" for the DB connection. The "infodba" user is automatically created by TcRS.
Evaluating: AW 3.4
Thanks for your reply
Yes I already login with infodba, but still fail
Vietbay CO., LTD VN
I Already login with infodba  " administrator" it passed the error but met other error
" engineering utility failure:  engineering.ultility.exceptionSmiley TongueOM002"
Please see the attach file for more detail
thanks!
Vietbay CO., LTD VN
Good afternoon, post a log E:\Apps\PLM\TEAMCENTER12\logs\1808021040\tc_install.log
Please see the attach file for TC_install.log
Vietbay CO., LTD VN
Please see the attach file for Log file
Vietbay CO., LTD VN
There are no errors in this log, I think you need to look at the syslog bmide_schema utility.
Dear Phenom
please all of log file
Vietbay CO., LTD VN
