Re: Error while adding SEEC feature
@ArthurRM which one is the lastest updated?
I don’t know, I’m interested in knowing this too, but it looks like SFB has a later date:
SFB Issue Date: Jul-11-2019
Integrations_Matrix_01-Apr-2019
I assume the information in the SFB should be more accurate.
@ArthurRM & @Manel_PLM24  - I only use the matrix for a quick check for major versions. The SFB is usually updated more often. It is probably under control of 2 different people, would be my guess, and maybe it is easier to get the SFB updated?
Jamie Griffis | PLM Solution Architect | Engineering USA
I agree with you @Jamie_Griffis, I have a question for you. As far as I know, there is an opportunity to subscribe to the SFB, can you write how to do this?
@ArthurRM - here are the details: https://www.plm.automation.siemens.com/global/en/support/email-subscription.html
Down side is you will get a ton of emails. You'll have to start filtering out the ones you don't want, like Technomatix, etc.
@Jamie_Griffis  thanks for the info, I'll try it!
